It is currently Thu Jul 10, 2025 8:04 pm
PostPosted: Mon Oct 16, 2006 11:02 am
I just started watching this weekends Handmade music. They're following a Gruhn guitar tech repairing a 30's D-18. Pretty interesting the guy used an espresso machine with the steamer running through a tube and a big needle to heat up the glue to remove the neck. Pretty interesting.
Seems like the moisture would cause damage though. nathan c39006.8367939815
nay
My blogs
Hand Made Gutar
Woodworker++
PostPosted: Mon Oct 16, 2006 11:22 am
Nay, I think that's probably the most common steam 'generator' you'll find in repair shops...
The moisture is just temporary. It's the long term exposures that aren't good (dry or wet)...
PostPosted: Mon Oct 16, 2006 11:24 am
I would have never thought of it. Ever. It's just too simple . The show was pretty good. The repairman reset the neck, replaced the bridge support and made a new bridge for it.
By the way. If you've never been to Gruhn's, it is awesome. I'm 2hrs away from Nashville, and each time I go I try to go to Gruhn's. $10k guitars within reach. Pretty neat.
nay
My blogs
Hand Made Gutar
Woodworker++
PostPosted: Mon Oct 16, 2006 1:41 pm
years ago we all used pressure cookers as out steam generators. big, heavy, cumbersome, needed a separate hotplate. pia!
the little domestic espresso machines were a boon, though sometimes you have to refill them on difficult necks.
and steaming can result in colateral damage, particularly with laminated b&s, connection to the neck block, and fiish blushes if you are not careful.
PostPosted: Tue Oct 17, 2006 8:41 am
Here's what I use.I found it at a thrift shop here for 8 bucks. It does the job. Stew-Mac sells a hose and needle for it.
